This command has been replaced with the following command: show l2vpn {vpls {{vpls_name} | vpws {{vpws_name}} {peeripaddress} {detail} | summary} . This command is still supported for backward compatibility, but it will be removed from a future release, so we recommend that you start using the new command.Displays VPLS and H-VPLS configuration and status information.
| vpls_name | Displays information for the specified vpls. |
| ipaddress | Specifies a VPLS peer for which to display information. |
| detail | Displays additional information in comprehensive detail format. |
N/A.
The show vpls command (without any optional parameters) displays all currently configured VPLS instances for the switch. The summarized list of VPLS instances is displayed in alphabetical order based on the vpls_name. Peers are displayed in the reverse of the order they were added.
When you specify a VPLS peer, the display includes a list of all PWs established to the peer, the PW status and PW ID, and information about each VPLS to which this peer belongs.
The show l2vpn command describes the display fields that appear when this command is entered with the detail option.
| Field | Definition |
| VPLS Name | VPLS instance or domain name. |
| VPN ID | Virtual Private Network identifier. |
| Source Address | Source IP address. |
| VCCV Status | Virtual Circuit Connectivity Verification (VCCV) feature status, which is either Enabled or Disabled. |
| VCCV Interval Time | Displays the configured VCCV interval time. |
| VCCV Fault Mulitplier | Displays the configured VCCV fault multiplier. |
| Redundancy Type | Displays the configured VPLS redundancy type, which is EAPS, ESRP, or None. |
| Service Interface | Displays a VLAN or VMAN interface name. |
| Admin State | Displays the administrative state of the VPLS, which is either Enabled or Disabled. |
| Oper State | Displays the operational state of the VPLS, which is either Enabled or Disabled. |
| MTU | Displays the maximum transmission unit (MTU) size for the VPLS. |
| Ethertype | Displays the ethertype for the service interface. |
| .1q tag | Displays the 802.1q priority tag for the VPLS. |
| Peer IP | Displays the IP address for the VPLS peer. |
| PW State | PW State represents the state,
or status, of a PW. The possible PW state values are:
| PW Uptime | PW Uptime is the elapsed time that the PW has been in the UP state. |
| PW Installed | PW Installed is a flag to indicate whether the PW is installed in hardware or not. If the PW is in the UP state, this field is True, otherwise, this field is False. |
| Local PW Status | Local PW Status displays the
VC status of the local PW. The values are:
| Remote PW Status | Remote PW Status is the VC status of the remote PW. The values for this field are the same values as for Local PW Status. |
| PW Mode | PW Mode describes how the PW
was configured. The values are:
| Transport LSP | Transport LSP is the LSP that is used to forward frames over the PW. When an LDP LSP is used as a transport, the display shows LDP LSP (Not configured). If an RSVP LSP is used, the name of the RSVP LSP being used as a transport LSP is displayed. An RSVP LSP can be specified as the LSP to use during VPLS configuration. |
| Next Hop I/F | Displays the interface name for the next hop router. |
| Next Hop Addr | Displays the interface IP address for the next hop router. |
| PW Rx Label | Receive label for the VPLS PW. |
| PW Rx Pkts | Total packets received on the VPLS PW. |
| PW Rx Bytes | Total bytes received on the VPLS PW. |
| Tx Label | Transmit label for the LSP. |
| PW Tx Label | Transmit label for the VPLS PW. |
| PW Tx Pkts | Total packets transmitted on the VPLS PW. |
| PW Tx Bytes | Total bytes transmitted on the VPLS PW. |
The following shows the display that appears when you enter the command without the detail option:
Switch.38 # show vpls L2VPN Name VPN ID Flags Services Name Peer IP State Flags --------------- ------ ------ --------------- --------------- ----- ------ Pws-3344 20 EAX--W NONE jwcvpls 99 EAX--L torix 11.100.100.219 Up C--NV- keeper 90 EAX--L NONE pws-1 2009 EAX--W pwserve 11.100.100.219 Up ----V- pws-10 70 EAX--W NONE pws-2 2008 EAX--W pw2serve 11.100.100.219 Up ---NV- pws-3 2007 EAX--W NONE sarsparilla 80 EAX--W NONE whoopwoo 100 EAX--L NONE 11.100.100.219 Down C--N-- VPN Flags: (E) Admin Enabled, (A) Oper Active, (I) Include Tag, (X) Exclude Tag, (T) Ethertype Configured, (V) VCCV HC Enabled, (W) VPN Type VPWS, (L) VPN Type VPLS Peer Flags: (C) Core Peer, (S) Spoke Peer, (A) Active Core, (p) Configured Primary Core, (s) Configured Secondary Core, (N) Named LSP Configured, (V) VCCV HC Capabilities Negotiated, (F) VCCV HC Failed ---------------------------------------- Total number of configured L2VPNs: 9 Total number of active L2VPNs: 3 Total number of configured PWs: 4 Total number of active PWs: 3 PWs auto-selecting transport LSP: 1 PWs configured with a transport LSP: 3 PWs using LDP for transport: 0 PWs using RSVP for transport: 4 PWs using static for transport: 0
The following shows summary L2 VPN information for the specified VPLS peer:
Switch.451 # sh vpls peer 2.2.2.2 L2VPN Name VPN ID Flags Services Name Peer IP State Flags --------------- ------ ------ --------------- --------------- ----- ------ vs1 105 EAX--L cust1 2.2.2.2 UP CAp-V- VPN Flags: (E) Admin Enabled, (A) Oper Active, (I) Include Tag, (X) Exclude Tag, (T) Ethertype Configured, (V) VCCV HC Enabled, (W) VPN Type VPWS, (L) VPN Type VPLS Peer Flags: (C) Core Peer, (S) Spoke Peer, (A) Active Core, (p) Configured Primary Core, (s) Configured Secondary Core, (N) Named LSP Configured, (V) VCCV HC Capabilities Negotiated, (F) VCCV HC Failed
The following shows detailed L2 VPN information for the specified VPLS peer:
Switch.452 # sh vpls peer 11.100.100.210 detail VPLS Name : vpls10 VPN ID : 10 Admin State : Enabled Source Address : 11.100.100.212 Oper State : Enabled VCCV Status : Disabled MTU : 1500 VCCV Interval Time : 5 sec. Ethertype : 0x8100 VCCV Fault Multiplier : 4 .1q tag : exclude L2VPN Type : VPLS Redundancy : None Service Interface : vlan10 Peer IP : 11.100.100.210 PW State : Up PW Uptime : 18d:0h:28m:26s PW Installed : True Local PW Status : No Faults Remote PW Status : No Faults PW Mode : Core-to-Core Transport LSP : LDP LSP (Not Configured) Next Hop I/F : o6vlan1 Next Hop Addr : 12.182.0.216 Tx Label : 0x00010 PW Rx Label : 0x80405 PW Tx Label : 0x80401 PW Rx Pkts : 3806161633 PW Tx Pkts : 4294967296 PW Rx Bytes : 912385942 PW Tx Bytes : 4294967296 MAC Limit : No Limit VCCV HC Status : Not Sending (VCCV Not Enabled For This VPLS) CC Type : Rtr Alert Total Pkts Sent : 0 CV Type : LSP Ping Total Pkts Rcvd : 0 Send Next Pkt : -- Total Failures : 0 Pkts During Last Failure : 0 Last Failure Tm : --
The following command shows the status of L2VPN Sharing configuration. If L2VPN Sharing is enabled, and more than 1 Transport LSP is configured, the output will display the status of each Transport LSP. The following example shows VPLS instance “vpls1” with LSP sharing enabled, with 2 Transport LSPs configured and programmed into HW.
* dut1.11 # show vpls detail
L2VPN Name: vpls1
VPN ID : 91 Admin State : Enabled
Source Address : 20.20.20.91 Oper State : Enabled
Service Interface : vlan91
Peer IP: 20.20.20.83
PW State : Up
PW Uptime : 2d:22h:28m:44s
PW Installed : True
Remote I/F MTU : 1500
Transport LSP : lsp1 (Configured)
Next Hop I/F : vlan21
Next Hop Addr : 10.0.21.92 Tx Label : 0x00074
Transport LSP : lsp2 (Configured)
Next Hop Addr : 10.0.21.92 Tx Label : 0x00077
PW Rx Label : 0x00075 PW Tx Label : 0x00085
PW Rx Pkts : 0 PW Tx Pkts : 0
PW Rx Bytes : 0 PW Tx Bytes : 0
VCCV HC Status : Not Sending (VCCV Not Enabled For This L2VPN)
Send Next Pkt : --
Last Failure Tm: --
Total number of configured L2VPNs: 1
Total number of active L2VPNs: 1
Total number of configured PWs: 1
Total number of active PWs: 1
Total number of ready PWs: 0
PWs auto-selecting transport LSP: 0
PWs configured with a transport LSP: 1
PWs using RSVP for transport: 1
* - Indicates LSP is configured, but not installed in HW because L2VPN Sharing is disabled.
The following example shows VPLS instance “vpls1” with LSP sharing disabled, with 2 Transport LSPs configured, but only 1 LSP programmed into HW (because sharing is disabled).
L2VPN Name: vpls1
PW State : Up
PW Installed : True
Transport LSP : lsp2 (Configured*)
Send Next Pkt : --
This following shows VPLS instance “vpls1” with LSP sharing enabled, 2 LSPs configured, but only 1 LSP programmed into HW. (LSP2 is disabled).
* dut1.13 # show vpls detail L2VPN
Peer IP: 20.20.20.83 PW
State : Up
PW Uptime : 2d:22h:30m:13s
PW Installed : True
Next Hop I/F : --
Next Hop Addr : -- Tx Label : --
Send Next Pkt : --
Last Failure Tm: --
The following shows VPLS instance “vpls1” with LSP Sharing enabled, with 5 Transport LSPs configured and programmed into HW.
* dut1.19 # show vpls detail
L2VPN Name: vpls1
PW State : Up
PW Uptime : 2d:22h:31m:54s
PW Installed : True
Next Hop Addr: 10.0.21.92 Tx Label : 0x00077
Transport LSP : lsp3 (Configured)
Next Hop Addr: 10.0.21.92 Tx Label : 0x00075
Transport LSP : lsp4 (Configured)
Next Hop Addr: 10.0.21.92 Tx Label : 0x00076
Transport LSP : lsp5 (Configured)
Next Hop Addr: 10.0.21.92 Tx Label : 0x00078
Send Next Pkt : --
Last Failure Tm: --
This command was first available in ExtremeXOS 11.6.
This command was updated to display flags for H-VPLS spoke nodes and protected VPLS and H-VPLS in ExtremeXOS 12.1.
The output for this command was modified in ExtremeXOS 12.2.2.
The output for this command was modified in ExtremeXOS 15.4 to display LSP sharing information.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
